harold1946
Jun 14, 2013Explorer
Acei wrote:harold1946 wrote:
Just as an example and by no means the only solar set up, but works well for us.
We are full timers and camp off grid 90% of the time. We have an Amana 18.5 cu.ft. residential refer with icemaker and run it on a MSW inverter.
Our batteries are 3- Deka 8D 12 volt AGMsw totaling 735 AH. We have 645 watts of solar.
My advice is that if you go with around 100 watts of solar for each 100 amp hours of storage capacity, you will be safely in the ballpark under most conditions, but there will be times when conditions will require some form of generating power other than solar.
This seems to be pretty close to my end-goal. Why did you go with 3x12V setup instead of 6V setup?
Also, that's a 3-panel setup, correct? What sized trailer do you own that accommodated these panels?
Thanks for the advises.
My battery compartment had the room for the large 8D,s and I am partial to AGMs. Other than that, just my choice.
Yes its a 3 panel set up and the motorhome is a 35 footer.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
