time2roll
Jun 14, 2013Nomad
I think that would be consided a nominal 36 volt panel as it has enough voltage to charge a 36 volt battery. Not sure the nominal ratings are given much once you get over nominal 24 volts because the primary market is not charging small batteries.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
