harold1946
Jun 15, 2013Explorer
pianotuna wrote:
Hi,
Again I'll regret replying, I suspect.
Harold, no one in their right mind on a brand new install would mix different format panels such as mono and amorphous. Of course it can be done. That doesn't make it a good idea, and recommending it is ill advised.
I'd love to expand my system even though it more than meets my needs. I would certain add another controller if I did so.harold1946 wrote:pianotuna wrote:
Hi harold,
mono, poly and amorphous eh? Are you daft?
Still waiting on your explination on why it can not be done as long as they are all 12 volt.
I have seen several applications using both amorphous and monocrystaline, both supplying power to the same controller.
I believe the "daft" one, or ignorant one is you.
Ignorant adjective; unaware, uninformed
Again you spoke without understanding what was said. It was asked whether or not it could be done and the answer is yes
If you will go back and reread my reply, it is quite obvious to even the most casual observer that made I no recommendation of any kind. :S
If you read some of the latest posts you will notice others have done so.
I can understand why you would regret it. You spoke without a full comprehension of what was said again.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
