westend
Jun 15, 2013Explorer
harold1946 wrote:Just so this doesn't get lost in personal diatribe: Mixing different modules that have different output specifications, even if of the same construction type, may not work out well. This is especially true if using just one controller and modules are wired in parallel. The controller may get confused as to the operating input and efficiency will suffer.pianotuna wrote:
Hi harold,
mono, poly and amorphous eh? Are you daft?
Still waiting on your explination on why it can not be done as long as they are all 12 volt.
I have seen several applications using both amorphous and monocrystaline, both supplying power to the same controller.
I believe the "daft" one, or ignorant one is you.
Ignorant adjective; unaware, uninformed
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
