Acei
Jun 15, 2013Explorer
Thanks for the link - I've bookmarked it. I will definitely consider the 2V scenario as well. I was heavily favoring the 6x6V setup because of in case one of them fail and still having 12V power but I also ready from somewhere else that batteries simply don't fail often enough to consider this a scenario, as long as it is maintained correctly. So perhaps 2V path is ok as well.
pianotuna wrote:
Hi Acei,
Be aware that the taller the battery the more important it is to use a charging routine that helps prevent stratification.
For a bank of three 12 volt batteries (6 x 2 = 12) there is only one method to wire them in a balanced manner. Only method #3 on this page will work: correctly interconnecting multiple twelve volt batteries
Others may say it doesn't matter--but unless there is a compelling reason to not optimize charging and discharging why not do it the best possible way?
In your shoes I'd still consider two volt jars such as the Trojan L16RE-2V fourth one down on the chartAcei wrote:
How about six of the following?
http://www.civicsolar.com/product/trojan-j305e-6v-305ah-flooded-battery
It is rated at 305Ah.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
