Acei
Jun 16, 2013Explorer
smkettner wrote:
Smaller controller at 1/2 the amps. (45 vs 80)
Smaller battery cabling to inverter.
Better balance with four 6v batteries in series. Eliminates parallel battery issues.
Yes the higher power items will be more efficient. Even the controller has better efficiency.
Not saying it is end all better but larger systems tend to use higher voltage.
Sounds interesting. So some components will be cheaper but there will be an additional converter (24->12v)?
What is this "parallel battery issue" you are referring to?
Also, I wonder if there's any Danfross 24V fridge around...
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
