Acei's avatar
Acei
How much power does solar panels actually generate?
Lets say the solar panel is rated at 500w, how much power should I expect it to generate on a sunny day vs cloudy day vs rainy day?
As a separate question, is it possible to run a residential fridge 24/7 on a solar panel + batteries? If so, what kind of setup would I need? This will be done on a full-timing 5th wheel unit pulled by a dually, so weight should't be a problem.
  • A 100 watt light bulb will use 100 watts of electricity.
    If you have a 500w solar panel that is what you should get on a sunny day.
    I can run our fridge on battery for several days and we have a very small solar panel just to maintain charge.
Looking for advice before your next adventure? Look no further.25,174 PostsLatest Activity: Oct 25, 2025
