Johno02
Jan 15, 2019Explorer
I installed a led strip over our slide in exactly the same location. The one I used had sticky tape on the back, so I just stuck it in place. You can just reach over the top and feel it. Mine, being one of the cheaper (16 foot or 5 meter) strips from ebay also has a problem with about half of it going off on occasion. I just reach over and rub it where it goes dark, and usually it will come back on. So the problem is just a bad spot in the strip, and a bit of pressure seems to fix the connection for a while. You probably have the same type of problem, the best fix is to pull it off and reinstall a better quality strip, but it will cost a lot more. Apparently temperature changes make it expand and contract, which breaks the connections. But I love the indirect light it gives.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
