Johno02
Jan 15, 2019Explorer
Be sure and get the strips that are 12V. that way, no 110v power is required, and it can be wired directly into any 12V source. Attached wire to strip before installation. Then just pressed the strip in place with the sticky on it. Wire attached at front corner. wire runs down the front, on the back of the wood, attached with wire clips. Ours is a motor home, so I was going to get 12V from under dash somewhere, but found a unused, fused, 12V power wire under the drivers seat for a power seat. I do not have the power seat, so I just used that for power to the lights. Installed an in-line switch in the cord about halfway up the slide, where it is easy to get to. Left enough slack in the wire for the slide to come in and out without binding. slack wire hides under driver seat.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
