schlep1967
Jan 16, 2019Nomad
DarkSkySeeker wrote:schlep1967 wrote:
Other option is to remove the board/trim across the front.
Do you think there are fasteners under those end caps?
I don't know. My slide trim doesn't have end caps. What I can see on mine is that they used something like a brad nailer to attach the trim and then used a wood putty to fill the holes. You may have to pry it off carefully which would most likely pull the nails through the back. And then use a brad nailer with nails that have brown painted heads on them to put it back up.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
