BurbMan
May 04, 2021Explorer III
Our 34' TT was 6900 lbs empty and 8500 lbs loaded, and it wasn't even a toy hauler....I suspect you are much heavier than you think you are. You may just need to move the toy(s) forward some in the garage to add some tongue weight.
Sounds like you're headed down a path that many on this forum, including myself, have been down before. The coil springs in the 1500 trucks aren't able to resist lateral forces like the leaf springs in HD trucks. The fact that you added air bags in the coils to level the truck not only aggravates the problem, but is a red flag that the WD hitch is not as "dialed in" as you think it is. LT tires help some but there's only so much you can do there.
Load the trailer and get it weighed, see if you can adjust loaded to improve performance. At the end of the day, I think a 2500 is in your future. BTW, you don't need a diesel, the 6.4 hemi will handle that weight just fine.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
