ktmrfs
May 05, 2021Explorer III
are you sure the WD hitch is properly set up and transferring ENOUGH weight back to the front axle??
Several friends of mine complained of issues like yours and when I examined their setup the hitch was NOT transferring enough weight back to the front. so... the front end was lifted, camber was affected and the front end wandered to easily. Once the hitch was adjusted to put enough weight back on the front end the difference in handling was dramatic.
so, check and see if the front wheelwell height is the same or only slightly higher loaded than unloaded. You do NOT want it lower loaded,
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
