JRscooby
May 06, 2021Explorer II
MyersAvionics wrote:
Thank you for all the input. I added the airbags just as a recommendation from a friend. I sometimes forget to fill them up when towing and don't really notice a difference to be honest.
The plan at the moment is putting better tires on. It is currently at the shop getting the Bridgestone Dueler A/T Revo 3's installed. Then I'm going to load up the trailer and take it to a CAT scale and get it weighed; Once without the weight distribution and once with to see the different load points for the axels. At that point, I'll readjust as needed. I don't carry anything too heavy in the back. Just up to 3 dirt bikes (<700lbs). We then put all luggage and so forth in the front bedroom to help distribute the weight.
After doing the above, I'll take it for a test drive and see how it does.
If it's still white knuckled driving, I will spring for the ProPride hitch. That's a tough 3k bill to swallow for a hitch, but it's cheaper than a 60k+ truck.
Finally, if all else fails we have discussed selling the trailer and getting a toyhauler RV. Talking big bucks there, so I'd like to avoid that!
Your trip to the Cat. Make 1 pass, hooked up like you tow, another with just TV. I have never understood what useful info is gained with loose bars, but the change in weight of TV, and where that weight rides is important info.
BTW, if you tell them it is re-weigh for the 2nd (or more) passes only charge a fraction.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
