MyersAvionics
May 07, 2021Explorer
Thanks for all the feedback. I think I have a solid plan going forward.
$1,300 later, I have some solid tires on the truck. I'm going to look up to see how much pressure I should be running in them when towing. The dealer put 40psi in and when using a tire pressure calculator it shows I should run 52psi.
Next weekend, I'm doing a short drive for a race. I'm going to load up the camper and then take it to a CAT scale. I'll do 2 passes. One with the TV by itself and then another with the camper to see how the weight is distributed. I'll get it all sorted to ensure weight is properly distributed. Note that I don't have any 'big' toys in the back. Just a couple modern dirtbikes so they weigh a little over 200lbs each. No big 1500lbs SXS's being loaded!
After that trip, if I still feel it is warranted, I'll spring from the ProPride hitch so I have it for a trip to the UP to race later this month. That will be a bit longer 10hr drive so it would be nice to have.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
