Kavoom
May 11, 2021Explorer
MyersAvionics wrote:
Hello All,
Curious on how I can avoid wind blowing the camper and my truck all over the place to the point of it being really annoying to drive and causing me to not even want to use it.
I have RAM 1500 with the 5.7 V8. It doesn't work too hard to pull my 29' toy hauler (7k lbs empty and ~8.5k with stuff loaded) at 65mph down the road. The problem comes in that even with slight side wind gusts I'm blown all over the place and I have to slow down to about 50mph to keep it drivable.
I have a BlueOx hitch with sway controls as well as the trailer friction sway control.
I have LT tires and after getting the weight distribution down pat, I have also installed airbags in the springs to keep the truck level. This helped, but I am still getting blown around the road.
I'm to the point of looking at a larger 2500 diesel RAM, or a full on drivable RV toyhauler, or just an RV that I would put a standard trail behind.
Before I go to these (expensive) extremes. Does anyone on here have any advice on something I could be missing?
Thank you,
Well, imho, I think Ram 1500 and 8.5K says it all... I have the same with a 10,500 max (yes, within capacity) at around 6500 loaded (5500 dry) and 800 wet tongue weight (27 feet 4 inches) and it seems to be a sweet spot. But you get a good wind gust and it lets you know in an unpleasant way... I have a Eastway E2 10K and it does a good job of allowing me to NOT lose control... Oh, I did get the after market airbags off Amazon installed for 280.00. They "damp" movement.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
