MyersAvionics
May 11, 2021Explorer
mr_andyj wrote:
You did not say which Ram you have. Is it one of those dinky short wheelbase trucks with single cab and 5 foot bed, or is it a crew cab with an 8 foot bed?
Wheelbase makes a difference.
A long wheel base will make towing easier than with a short wheelbase.
I have doubt about what changing tires will do to combat wind.
If the wind blows against the side of your huge, yet fairly light-for-the-size trailer, then it is going to move.
The guy mentioned AirTabs, and that, or doing something to smooth out the airflow behind the trailer might be the biggest thing you can do to help. Think of those door flap things the big rigs have on some of their 53 foot trailers. That helps with mpg's but also with control as it smooths out the air flowing off the rear.
On my trailers I put all the roof junk at the front and nothing on the roof on the rear half as I want the air the have time to smooth out before dropping off the back. Every little bit helps.
I have the quad cab with the 6'4" bed. Looking at all the options, the wife and I are going to spring for the ProPride 3P hitch. It's a good investment in the long run. It retains its value well and if I do go to a 2500 we'll transfer its use over to that.
I just need to determine the loaded tongue weight to determine which version to purchase. I'm thinking the 1000 or 1400. The toyhauler is just shy of 7k lbs dry. Add water, bikes, and materials and I'm easily 8k lbs.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
