shawdowboss
Jan 24, 2015Explorer
Sounds like the steering needs to be secured. With a seatbelt loop through the wheel, latch, then jerk the belt to get the lock to set and retract all the slack. Else use a ratchet strap, but tie it to the bottom seat frame, not the brake pedal. You may damage the pedal mech if the wheel jerked or you over tighten the strap.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
