wilanddij
Nov 25, 2014Explorer
Unless you have very, very excellent depth perception and an accurate aiming point, a solid arm towbar is most likely a two person hookup.
As Blue Ox says, the towbar should be level to no more than 4" higher on the MH end. It should never be higher on the toad than it is on the MH for a very good reason. If it is higher on the toad, the front end could lift in a panic stop situation and make a mess of the MH rear fiberglass.
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 30, 2026
