jornvango's avatar
jornvango
Explorer II
Nov 24, 2014
How to hook up a toad to an RV using a tow bar?
I just installed base plates on my 2002 Wrangler and have purchased a Smitty Bilt tow bar to connect to the tow hook on my RV.
Before I do something wrong, I wanted to ask ...
1) Is there a right or wrong way to connect the Wrangler to the RV, as in, do you connect the tow bar first to the RV and then drive the Wrangler in position to attach the tow bar arms? Or, vice versa, where you first connect the arms to the Wrangler and then hook it onto the RV's tow hook (much like a regular trailer would work)?
2) The base plates on the Wrangler sit a little higher than the tow hook on the RV, so the tow bar will not be completely level to the ground. Is this a potential problem?
Thanks!
Jorn
P.S. Yes, I have already installed a lighting kit on the Wrangler to connect to the RV (so the blinkers, running lights, ... will work while towed) + I have a braking system (BrakeBuddy) in the Wrangler.
  • Here is what Blue Ox says about leveling the tow bar.
    "Verify the baseplate attachment tabs are level or no more
    than 4” lower than the receiver hitch. Adjust with a drop/rise
    receiver as necessary."
  • tenbear wrote:
    I have a Blue Ox tow bar but I suspect the principals are the same.
    My tow bar assembly is attached to the MH and stays there all season. The toad is driven into position behind the MH.
    Ideally the tow bars should be level. I use a drop receiver to accomplish his. It seems that different manufacturers have different requirements. Check your tow bar owners manual.
    I take it back. Clearly, you couldn't leave the towbar attached to the MH or the toad.
  • You drive up. It is tricky getting it aligned if you have fixed arm tow bar. I had one like that and it didn't last too long.
    I got one with arms you could unlock so you could be off several inches and still connect.
    Watch Craig's List.
  • Yes, that's the tow bar I have.
    The Smittybilt website doesn't mention how level it has to be, or I'm looking in the wrong places: http://www.smittybilt.com/product/index/168.htm
    Looks like yours needs to be level, I prefer the blue ox style with telescoping bars - easy to install.
    Just wondering why you got this one.
  • I have a Blue Ox tow bar but I suspect the principals are the same.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
