wa8yxm
Aug 11, 2022Explorer III
bukhrn wrote:
if what you do works, I'd stick with it.
Agreed. There are many options that's likely one of the best.
Another is this. if it is inside a copartment you can cut a piece of wood to "Slide" under the door (Cut it in a "U" shape)
The door fits in the "U" and the wood either side of it both holds it open (By "Banging" gently against the frame) and prevents it from opening too far (Tight fit it) I forget how I did mine.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
