StonedPanther
Jul 28, 2023Explorer III
Grand Design uses Alpha Systems Superflex roofing, now a Lippert company. You don't get the lap sealant off of Superflex without destroying the Superflex itself, which is what the OP is running into. That's why they make "patch kits" available for an overpriced amount on the Lippert online store. If you get lap sealant off of Superflex without stretching it or tearing it you're Superman.
The way you would repair those areas is cut around the lap sealant and remove it and the piece of membrane under it, then patch the membrane back in using the material that comes in Lipperts overpriced patch kit.
PATCH KIT
PATCH KIT
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
