2112's avatar
2112
Explorer II
Sep 22, 2013
How To Save That High $ Caulk
I thought I would share this tip:
I bought this tube of Geocel in 2010 for $9. I used a small amount to seal a leak and then sealed it up in a bag with my Food Saver vacuum sealer. I opened it again in 2012 to seal another leak and then resealed it in the same bag.
I had to open it again this morning to seal another leak and it flowed as well as it did the day I bought it.
Each time I use a very small amount so at this rate this tube should last me many years to come.
  • Thanks, I will give this a try. I've been wrapping the ends with a square of good hvac foil tape, with good results. But the sealing bag can only help some more.
  • Great tip! Thank you. I cannot count how many tubes of caulk I have had to throw away because the stuff hardened in the tube. I am going to try this one out! Thanks again. :) :) :)
    Barney
  • PloFlex is great I have used it for many years. I use the end of a rubber glove and rubber band to seal the end. Works great. Their liquid sealer in the qt is also good.
Looking for advice before your next adventure? Look no further.25,154 PostsLatest Activity: Aug 08, 2025
