PastorCharlie
Jan 21, 2018Explorer
Use the Mode button to access the different features of your system. If it has a Heat Pump it will show as you push the Mode button. If it does not show (and you are sure it has a Heat Pump)then you will have to go into the Menu settings to enable it.
Try turning off all power (120V AND 12V) for a few seconds and see that helps when repowered.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
