Fastfwd75
Jun 24, 2014Explorer
Artum Snowbird wrote:
You would want to connect an inverter directly to your battery. Most TV plugs in RV's are not designed to produce much more than 80 watts and the wiring is extremely light to the plug. Far better to use a piece of No. 8 wire and hook up to an inverter of several hundred watts.
I was afraid of that. I think my limited skills would be enough to add a 12v outlet from the panel assuming I can find a way to splice from something or there is a free terminal somewhere.
Starting to run wires outside from the battery box to the inside is a completely different story. Trailer does not seem to be build with access panels to check/repair wiring.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
