hedge
Jun 24, 2014Explorer
Fastfwd75 wrote:hedge wrote:
You have a USB plug in the dash, use that to power the ipad.
In the back of the console you have a built in 150w inverter, use that for the laptop.
2 problems with that.
- The Sync USB plug is standard USB and limited to 0.5-0.9 amp. The apple stuff does some electronic handshaking and will draw almost 2 amp. My phone actually discharges when using navigation while plugged into the sync USB.
- I have the 6 seats so no 150w built-in inverter. I added an inverter anyway so 120v in the truck is taken care of. I want things to work from the trailer too.
Interesting, I only have the basic sync system without nav on my trucks since 2009 and never had a problem charging iphones (3G, 4S, 5). I can see how it may not charge an ipad very fast as they pull 2 amps if they can get it.
I just recently added a bunch of 12v plugs and usb plugs inside my truck camper. It doesn't directly help you but may be another option.
USB and 12V plugs
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
