24rules
May 13, 2013Explorer
i think you need to check your valve that needs to be open when you fill with city water once the fresh water tank is full you need to shut that fill valve or the only thing that is going to happen when the pump is turned on is that it will just recirculate from pump back into fresh water tank this same thing happened to me this spring with that valve opened there will not be any pressure built up to faucets if you trace your fill tube you will find the valve mine is on the opposite side of the pipe that feeds all faucets
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
