walker2413
May 14, 2013Explorer
Yes, I did fill the water heater on city water.
Today I hooked the inlet of the pump to a pail of water, the pump sucked the water out of the pail no problem. I then set my compressor's air pressure down to 25 psi and I pumped some air down the line going to the tank. Water started to go out the overflow. When I removed the air, water started running down the hose. I reconnected it to the pump. I opened up the cold water tap and managed to get all of the cold water taps running pretty well. I then started turning the hot water taps. The hot water system may be the problem, after trying to get them running smoothly, I lost pressure and am back to where I started.
Any ideas?
Thanks,
Bill W
Any ideas?
Thanks,
Bill W
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
