walker2413
May 17, 2013Explorer
jamnw wrote:
You said: Water started to go out the overflow. When I removed the air, water started running down the hose.
That seems odd to me. Are the intake and overflow lines tied together? I don't think mine are. Mine has a separate overflow line.
If you pump air through the intake, I figured as long as there is no obstruction, you would blow a bunch of bubbles. And the air would go back out the fill tube and or the overflow tube.
It sounds like you are sucking air or have an obstruction. Kind of like when you try to drink through a straw with a crack in it.
Hi,
Yes there was a lot of bubbling in the tank when I was blowing air down it. The water then exited the fill tube and overflow. But removing the air, seemed to get the water flowing. I tried the same trick and again with no luck though.
Bill W
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
