silvercorvette
Jun 22, 2013Explorer
I did the same dumb thing for the 4th or 5th time
This time was the worst.
My front A/C is not working and I have a new part waiting for me in PA to be installed on my trip back home to SC.
The front and rear A/Cs both control an A/C, heat pump and furnace.
I still able to use the front furnace to take the chill out at night. In the morning I turn off the front furnace which is controlled by A/C controller. I forgot to turn off the front furnace a few times before turning on the rear A/C and wound up having the rear unit pumping cold air and the cold air blowing on the front unit cause the furnace to come on.
Today I was not feeling well but I had to go out and fill up an empty propane tank, and forgot to turn on the A/C before I left so the RV was hot when I returned. When I got back and went straight to bed because I was feeling worst when I got back than when I left.
I was laying down in be for a 1/2 hour maybe more and I and getting real hot so I get out of bed to get a soda and when I step on the vent the metal was hot from blowing hot air. This is not the first time I made the same stupid mistake but I hope it is the last one. The worst that happen was I burned off a lot of propane and sweated a lot so at lest it was a mistake that cost a lot of money to fix something I broke. I the front A/C was not broken it probably would not have happened but I am going to post a note to remind me to turn off the heat before turning on the A/C.
If you camp long enough you will probably make every stupid mistake there is to make I just don't like repeating the same mistake
