pira114 wrote:
I top off my tanks after every single trip. Regardless of how long I'm using them. Use one tank at a time, so only top off the one I used. Unless, of course, I used both.
Is this really that hard?
In many jurisdictions propane fill is by weight, not volume, including here in Ontario where I am. If I take a 20 lb tank in for a fill I pay for a 20 lb fill whether the tank is completely empty or still has some left in it ... aside from the inconvenience no way would I refill after every trip. I have dual tanks and do what many others do - run just one tank until it's empty, then manually switch over to the second tank. Although there's no reason for it to happen, if I ever did run both tanks dry I could run our trailer off the stand alone 5 lb tank I use to run our Weber Q grill or even a couple of 16.4 oz canisters I always carry as spares using a
Second Chance Adapter. There's absolutely no reason to ever run out of propane and no reason to ever have to refill until the tanks run completely empty ... it this really that hard? :S
