The_Texan
Apr 19, 2014Explorer
Idaho SR-55 bridge warning
A heads up to all RVers using SR-55 through Cascade. DOT has reduced the axle weight for ALL vehicles on the north bridge to 9K/axle and will be further reducing it to 6K/axle this week. They are serious about this as the bridge is now considered unsafe for any heavier weight and they are going to start setting up temp scales on both sides of the bridge. They also plan to have flaggers on both sides to control traffic 24/7, as they say 2 max weight vehicles crossing in opposite direction could cause the bridge to collapse. These weights and restrictions apply to ALL vehicles, including RVs.
There is an alternate around the bridge, Thunder Mountain Rd, but it is approx. 4 miles of dirt and holes, plus right now is closed because a commercial rig tried to use it and is stuck hard in a soft spot.
They will start emergency construction of a new 5 lane bridge on 1 July, but the weight restriction will remain in effect for a couple years. Please check with IDOT before driving all the way up here and not be allowed to continue.
