Hikerdogs
Aug 18, 2016Explorer
It's definitely a Roadmaster Brakemaster 9060 system. I've installed 2 of them in our motorhomes. If it's an older system the tank drain valve will be similar to the drain petcock on your radiator . The later models have the ball vale as in the picture you provided.
As for the proportioning valve it's mounted to the frame rail and taps into the hydraulic brake line. As the brake pedal is depressed the hydraulic pressure moves a diaphragm in the valve. This in turn proportionally opens the air valve and allows air to go to the cylinder attached to the brake pedal in the towed vehicle.
Here's a link to the proportioning valve:
https://www.etrailer.com/Accessories-and-Parts/Roadmaster/RM-900001.html
Here's what the Roadmaster towed vehicle air cylinder and mounting bracket look like:
https://www.etrailer.com/Tow-Bar-Braking-Systems/Roadmaster/RM-9060-900002.html
The round bracket mounts to the floor under the driver's seat. The clamp attaches to the brake pedal. I would be hesitant to use the one you fabricated in that I doubt it would have the same rate of response or amount of force applied as the one from Roadmaster that's calibrated for the system. I doubt you'll get proportional braking using a smaller diameter cylinder with a longer stroke. Also keep in mind the system is supplying sufficient air pressure (100 - 120 psi) to operate what's known as a dead brake pedal. I would be surprised if your pedal mounting system (looks like wire ties) could withstand the pressure.
Here's a link to the Roadmaster installation and owners manuals:
Installation:
http://roadmasterinc.com/pdf/85-1811-19.pdf
Owners Manual:
http://roadmasterinc.com/pdf/85-1991-16.pdf
All the manuals and parts you might need are available from Roadmaster:
http://roadmasterinc.com/index.php
This is an excellent braking system. We used it on our 2001 Winnebago Adventurer for well over 100,000 miles without a problem. We left it in the motorhome when we sold it. We have the same system in our 2013 Adventurer. Again it's gone over 26,000 miles without a problem
Be sure to read the owners manual. Part of the towing procedure includes pumping the brake pedal in the towed vehicle to deplete the vacuum in the power brake reservoir before attaching the cylinder. If there is still vacuum in the reservoir the brakes could lockup when the cylinder is activated. There's also a section dealing with "active" braking systems. These are systems that have power assist whether or not the vehicle is running. If you have a vehicle with this system you'll need to add a pressure regulator to the cylinder in the towed vehicle.
Installation:
Owners Manual:
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
