Old-Biscuit
Apr 17, 2013Explorer III
If a water line blew off your water heater would you not use the water heater again after fixing the water line??
If radiator hose blew.......would you not ever drive your rig again after fixing radiator hose?
You had a problem.......you fixed the problem.
Use the right equipment for the job.
Looking for advice before your next adventure? Look no further.25,205 PostsLatest Activity: Aug 18, 2026
