willald
Apr 17, 2013Explorer II
Old-Biscuit wrote:
If a water line blew off your water heater would you not use the water heater again after fixing the water line??
If radiator hose blew.......would you not ever drive your rig again after fixing radiator hose?
You had a problem.......you fixed the problem.
Use the right equipment for the job.
Haha, very good points, and 'twas exactly what I was expecting to hear.
The hose blow off incident was NOT the only incident or issue we've had. There's been a multitude, which have caused us to not have much confidence. The blow off incident was just the most recent, and the one that sticks out in memory the most. :)
I do plan to continue to use the 'right equipment' (lube pump) now that its working right. I was just trying to establish, confirm a good 'backup' solution to the lube pump, for when/if we have another issue.
Will
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
