willald
Apr 18, 2013Explorer II
F1bNorm wrote:
With the engine running, both power steering and power brakes would active. Something to consider?
I know.
Power brakes would not be a problem at all, as I use a ReadyBrake system, which is basically a surge system. Because of the way its designed, its just about impossible for it to ever 'over-brake' your toad, regardless whether the power brakes are on or not. It would actually help it some.
The power steering being on, is definitely something I've been thinking about as well. Based on what I understand about how power steering works, though, I don't think it will cause a problem. Also, if you do some reading, searching on this subject, you'll see where there are folks that have done this (idling) approach, and never had any issue with the power steering.
Will
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
