Lantley
May 06, 2013Nomad
Wow what a tale. Now if you would have only stuck with a towable RV your family could travel cramped up in a crew cab pickup like mine.
But you would not have any lube pump issues! LOL:B
I see the motorized RVs can be just a challenging/aggravating as the towables.
Good Luck, Now that the spraying tranny fluid has scarred you for life. Hopefully you get it all sorted out without losing any more fluid.
I like your creative out of the box thinking. But the idea of running two engines doesn't seem practical. I understand you don't plan to do it often, however I'm always a bit agitated when we drive two vehicles to the CG to carry additional passengers that won't squeeze into the crew cab.
I'm sure I'd be real disturbed if I were burning even more gas by towing an idling car.
But then again I didn't witness the spraying hose drama.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
