willald's avatar
willald
Explorer II
Apr 17, 2013
Idling engine while towing questions
..We now have two toads: DW's daily driver, a Kia Sedona van (that has Remco lube pump to allow towing), and my daily driver, a Ford Fusion Hybrid (flat-towable from the factory, woohoo!) Reality is that we will probably tow my Fusion most trips, as it is easier and a lot more fun. However, there still will be trips where we'll want the extra space the van offers, and will want to be able to bring/tow the van.
Due to several things that have happened that I'd rather not go into in detail, we do not trust the lube pump setup on the van anymore. It is not in any way Remco's fault, they have a great product that works great when properly installed (ours was not, bottom line, haha). Horrible luck we've had with a poor installation is the main reason we've lost confidence in the lube pump.
That being the case, until our confidence is restored in the lube pump, I am seriously considering taking the approach of disconnecting the lube pump and idling the van (in neutral) on the rare occasions we tow it (maybe once or twice a year).
I've searched, and read numerous threads about folks that have had success taking this approach (idling a toad in neutral when towing). I understand fully that it means miles will be logged, and the bad things that can happen if the engine dies or overheats. I'm willing to accept that risk, given how rare it is we will do this, and how rock solid and reliable the drivetrain in this van has always been for us.
My only question/concern with this practice, is whether or not the Kia's transmission will circulate fluid through the cooler when it is in neutral. If not, I will obviously scrap this idea. If it does, then I'm thinking this idling approach should work OK.
Anyone have any specific experience or knowledge that would indicate whether or not a 2007 Kia Sedona's transmissions would circulate fluid when in neutral?
I've already tried talking to Kia technicians, and basically got no real answer. Next option (which I may well do), will be to take a fluid line loose from the cooler while idling in neutral, and see if fluid flows. Thats probably what I'll have to do, to be sure (any other ideas on what I can do, to find out for certain that fluid is flowing through cooler when in neutral?)
On a separate, but related question: You think there'd be ANY market at all on Craigs list or wherever, for a like new, Remco LP-1 Lube pump setup? Enough, to be worth the time and $$ it'd cost to remove the lube pump setup entirely from the van and put it up for sale? :)
  • rjstractor wrote:
    Will, I must have lost track of your other thread. Sounds like you got the Readybrake installed in the Fusion ok?
    Not quite yet. I ordered the RB cable and Readystop unit, that is supposed to be here Wednesday. As I noted in that other thread, I found an RV shop/dealer that is experienced with Readybrake. They are willing to do the installation, and confident it can be done on our Fusion. Will probably be done one day next week, or maybe later this week, not sure yet.
    Will
  • Wow what a tale. Now if you would have only stuck with a towable RV your family could travel cramped up in a crew cab pickup like mine.
    But you would not have any lube pump issues! LOL:B
    I see the motorized RVs can be just a challenging/aggravating as the towables.
    Good Luck, Now that the spraying tranny fluid has scarred you for life. Hopefully you get it all sorted out without losing any more fluid.
    I like your creative out of the box thinking. But the idea of running two engines doesn't seem practical. I understand you don't plan to do it often, however I'm always a bit agitated when we drive two vehicles to the CG to carry additional passengers that won't squeeze into the crew cab.
    I'm sure I'd be real disturbed if I were burning even more gas by towing an idling car.
    But then again I didn't witness the spraying hose drama.
    Don't have to deal with the lube pump with our Ford Fusion. :)
    ..If I had stuck with the towable RV, instead I'd have to deal with......................Well, I won't go there, hahahahaha! :)
    ..The gas aspect is the least of my concerns with this approach, Lantley. Its only going to be idling, using very little fuel, even when going 65 mph. Would be getting incredible mileage, hahaha! :)
    I'll be more concerned about not being able to see the gauges on that engine (temperature, oil pressure, etc.) while its running. But, a small, portable wireless video camera and monitor will solve that, and may be something we look into if we do this idling thing a lot.
    Or better yet: Let one of the kids ride back there with a 2 way radio in their hand, and make them watch the dashboard! Oh, wait, I guess thats illegal. Drats! ;)
    ..But then again I didn't witness the spraying hose drama.
    Yeah, its a case where its hard to 'un-see' that, haha. I'll get over that eventually, and we'll probably be fine towing the van. Like I said, though, in the meantime, the Ford Fusion is aweseome. :)
    Will
    • Bbrandall23's avatar
      Bbrandall23
      Not sure if this info is still needed but you most definitely are pumping fluid through your transmission cooler at idle and it is scary that the dealer could not answer that question. Very scary. The only thing I would question is if your getting enough lubrication at high speeds and the reason I do is most trucks won't let your engine RPMs drop down to regular idle if you slip the transmission into neutral while driving down the highway at higher speeds it keeps them up above 1000 and the reason why is to ensure good lubrication to that transmission at those RPMs now that being said I have driven many of vehicles that will let the RPMs drop all the way down to regular idle at high speeds when slipped into neutral. My initial opinion on your situation is that you would be okay and I would believe the manufacturers take that very thing into consideration while tuning the vehicle they do at least with the GM trucks. I hope I shed some light on it for you and did not just cause more questions.
        Bbrandall23
        My 03 Jeep Grand Cherokee with 4.7 l V8 and auto trans will go to reg idle rpm at highway speeds when slipped into neutral. My 04 Silverado 2500 HD with 6.0 gas 4L80E trans will only let it go to regular rpm idle if road speeds are low. My 04 Silverado HD with Duramax and Allison is another story all together now I am not sure exactly what happened maybe someone can answer my question, one night while out of town working me and my brother were out looking for some back roads trying to have some fun and for some reason I got going about 50 or 60 and put the trans in neutral and let it cost no throttle and after the truck slowed to around 15 or 20 mph it straight to up just about locked up now I'm almost 100 percent positive it was in neutral my brother was kinda thinking more guessing I put it in reverse this was in my younger dumber days when I did used to do a little buzzed driving but it was maybe 2 or 3 beers at most over 2 hours period so that is the small chance he could be right. I am pretty dang certain though it was neutral just out of curiosity has anyone experienced this?
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
