Have to replace in 2004 National Tropi-Cal. Can't find replacement the same size. Can make new faceplate ,but would like to avoid the custom work. Any suggestions? Thank you.. Sherry
Yes the Jensen units National used are 1.5 DIN so nothing directly fits as a replacement. I don't believe even Jensen makes a 1.5 anymore. The easiest would probably be to make the hole bigger so a double din fits. Just make sure and pull the old radio out and double check clearance in all directions before starting mod.
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jul 01, 2026
