DrewE wrote:
There is of course also a fourth and even simpler option, which is to get a small inverter and plug the TV into the inverter and then connect the inverter to a convenient 12V power supply point, often a lighter plug where the TV is installed.  That can be done by anyone who can plug things into other things, and for a pretty small load like a TV it usually works fine.  (An XBox may prove more troublesome, as it's comparatively power hungry.)
This is what I did,I had no need for a large amount of power while off the grid nor the expense of a larger inverter.
The TV is all I wanted to use and it was not a 12volt.
This one works just fine.
