pasusan's avatar
pasusan
Inflatable Kayak questions
We are thinking of getting an inflatable kayak to take with us while traveling. We have a regular hard canoe, but aren't happy with the options to bring it with us (adding a rack to the top of the TV). So, I was thinking an inflatable that we could stow in the back of the truck.
What do you do to dry it before packing it up? Does it take a long time? Is it sort of like a pop up trailer where you can pack it up wet, then get it out to dry later?
Thanks for any insight...
  • We have this model Advanced Elements 1007 and really like it.
    I use a battery powered air mattress inflater to get most of the air in, and then have to use the more high powered manual pump to harden it up. I also have converted the wheels and frame from an old fertilizer spreader by removing the bucket and gears, and we tie the kayak onto that and with only a little weight on the bow, we pull it to the lake, then strap the carrying framework onto the back while we paddle.
    So, yes, we like to dry it out. Our model comes apart into floor, tubes, and outer canvas. It does take some time to dry it out, but it's so fun to paddle about on nice days. We usually spread the parts over a picnic table or even a rope between trees, then re-assemble it before folding it up. If we stay for a few days it just slips underneath the rig on a 9 by 12 tarp diagonally.
  • Here is a source for info on folding and inflatable canoes and kayaks in case you haven't seen it already.
    http://www.paddling.net/
    We have an Innova inflatable kayak and it is a pretty reasonable little boat. We generally just dry it off with a towel - that seems to be adequate.
    Manual air pumps are slowwwww. We use an electric and then get final pressure with the manual foot pump. Some models require pretty high pressures (more than 5 lbs pressure). This gives you a more rigid craft, but must be harder to pump up.
    Flat-bottomed boats are almost impossible to steer in a wind. If the boat doesn't have rounded or shallow V-shaped hull, then a rudder or skeg is necessary.
    Kayaks can pick up a lot of water from the paddles. It is nice to have raised seats or to add seats to keep from having to sit in a puddle.
    A fully inflated boat can over-pressurize and even pop in a hot sun. It's a good idea to depressurize when you are not using it.
  • I have a two person one from West Marine that we have used for years. Folds up to suitcase size. Depending on the climate; it takes a couple to several hours to completely dry the fabric portions. Wiping the inside with a towel speeds things up. If I anticipate using again in a day or so and it is still damp I will go ahead and fold it up and stow it.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 12, 2026
