AH64ID wrote:
Quite a few people commenting in this thread that should read the service buletien from Goodyear before they comment on Goodyear ST tires.
AFIK Goodyear is the only only with a bulletin allowing pressure to go higher than the sidewall rating and faster than the ST standard speed limit of 65.
Goodyear doesn't state 'sidewall pressure'
They state 'trailer placard for normal inflation and load conditions.
Cold MAX PSI on sidewall is just that.........MAX PSI COLD Inflation
If Goodyear tires, with the ST designation, are used at speeds between 66 and 75 mph (106 km/hand 120 km/h), we recommend the cold inflation pressure be increased by 10 psi (70 kPa) above the recommended pressure based on the trailer placard for normal inflation and load conditions
