frankdamp
Sep 11, 2014Explorer
Unless your RV can accelerate to 150 mph in a mile and a half with a dragging brake and then you can fold the wheels up into an enclosed compartment, using nitrogen is a waste of money.
Airplanes use it, which is where my example above comes from. When I was at Boeing, I did a lot of research into in-flight tire bursts and all of them involved dragging brakes on take-off. The heat stored in the brakes then heated up the bay where the retracted gear was stowed and the tires blew.
One incident I looked at, the tire bead had failed in tension, suggesting a pressure inside the tire reached about 12,000 psi in a spontaneous combustion explosion. All the incidents were with air inflation, so Boeing made a strong recommendation to switch to nitrogen, whic is now standard.
Nitrogen is a total waste of money on 70 mph road vehicles.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 20, 2026
