- FrankShoreExplorerCostco Tire Center uses nitrogen.
- azdryheatExplorerRegular air is 78% nitrogen. On that note, 100% nitrogen won't leak out of your tires as fast as air as the nitrogen molecules are larger. Nitrogen will also maintain a constant pressure regardless of temperature or elevation. I have no experience with nitrogen in my tires, I just carry an air compressor with me.
- DSDP_DonExplorerIf you were putting it in an airplane tire or a Nascar ride, it might be useful. In a motor home, it's a waste of money. Some say it reduces moisture issues, but most of todays RV rims are aluminum and it's not a problem. Once you have to add air to any of your tires, you're back to just regular air.
- Dog_FolksExplorer IINitrogen has benefits in tires used for air craft or race cars. For a vehicle at normal speeds, it serves no practical purpose. It is a profit center for the tire seller/dealer.
If it makes you feel better, spend the money on it. It won’t hurt, but remember that it is not as easy to find 100% Nitrogen for bring tires up to pressure.
Normal air contains 78% Nitrogen, so is it worth it for an extra 22%? I think not.
The next time I tow my trailer at 200 MPH or it has the name “Boeing” on it, I will use nitrogen. - jplante4Explorer IIUsed in airplanes for years, not only in tires but also in struts. The only issue I'd have is finding N2 on the road. I guess you could go to an airport.
Looking for advice before your next adventure? Look no further.25,181 PostsLatest Activity: Jan 22, 2026
