azrving
Jan 21, 2015Explorer
When you pull it off you may find that the sandwich design of the ceiling has collapsed or crushed together. The gasket is pretty firm rubber. I repaired a roof ac opening area and glued in small blocks of wood to give the area more support.
If this has been going on a while it may have messed up the plywood around there. If the membrane around that area is bubbled up or wavy it's damage to the plywood.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
