DanKirk's avatar
DanKirk
Install 30A on a Cable
I had considered installing a 30A RV plug on my house and using an extension cable to connect it to my trailer while parked on the street. But then I had the idea to install a 30A breaker in my power box, and connect it directly to a 30-foot long 3 conductor 6/3 SOOW cable with a box with a 30A RV outlet. I can keep the cabled coiled and hung inside my garage and run to the street when my trailer is there.
Is there an issue with running SOOW cable directly to a breaker in a power box?
  • What do you an anticipate using in your RV while parked in front of your home that would require 30 amp service? Do you plan on the electric cord laying across a sidewalk used by the public? If so, the purchase of an umbrella insurance policy would be wise.
  • As donn0128 said. I dont think you need 6/3. Probably 10/2 with ground or maybe 8/2 w ground. You could come out of your panel into a 30 amp rv box with a twist lock and make a cord that plugs in when needed. $30 at depot for the box
  • Do you absolutely have to have 30A. If all your going to do is run the refer for cool down prior to trips a 20A circuit is more than enough. Stringing a 30A line across the lawn and sidewalk is just asking for someone to get electrocuted.
Looking for advice before your next adventure? Look no further.25,176 PostsLatest Activity: Nov 14, 2025
