wa8yxm
May 11, 2016Explorer III
Can you hook up both a 50 and a 30 amp (And a 20) on the same pedestal at the same time?
Well, it depends.. on two things.. The branch breaker in the main power distribution panel and the wires from there to the pedestal.
If the wires are rated for 80 amps. and the breaker is 80 amps, and the 30 amp outlet and 20 amp are on differnet legs (How I'd wire that box but do check)
yes, you can
The RV park where I am each site has a 50 amp breaker back in the master panel. SO here.. NO.
yes, you can
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
