djgodden
May 11, 2016Explorer
Many good replies so far. Last year we installed a 100amp system to do just what you're asking. We have 2 trailers which use 50 amp and 30 amp respectively. After extensive research I purchased aluminum wiring, due to the cost of copper, rated to my needs and a dual 50/30 box (Connecticut Electric CESMPSC75GRHR 80-Amps/120240-Volt Circuit Protected RV Power Outlets.) I did all the work myself and ran the cable inside 3 inch PVC conduit but had an electrician do the final connections in my panel and to the new RV box. Easy peasy...
I liked the RV box because it's prewired so there's no magic in getting the wires powered correctly for an RV. Attach the feeds and the box splits it up accordingly.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
