badbob1's avatar
badbob1
Installing brake for 2011 Equinox
Looking at Invisibrake for my 2011 Equinox but no way it will fit under front seats. Where and what type of brake have others used for an Equinox? Already have a Sterling tow bar so readybrake not an option at this time. Can I mount the invisibrake under hood?
Thank You
BadBob
  • We also are looking at the Chev Equinox along with the Honda CRV. After using a braking system that never knew if it worked, I plan to install the M&G Braking System. They are located about eighty miles from me but I know they have dealers across the US that install their system.
  • We have the US Gear Unified brake system that is much like your Invisibrake and on our Terrain (1st cousin to your Equinox) I install the unit under the dash board on the passenger side. Pulled back the carpet and bolted the unit to the floor pan up as high as I could get it. Ran the cable (and wires) back over to the drivers side and recovered the unit with the carpet.
    Never know it's there nor can you see it.
    Hope this helps
    Ron
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 22, 2025
