Goo
Sep 03, 2015Explorer
I found that mine was quite easy. After it was set up so that the trailer was level, I tightened the bars so that 1/2 the front end lift came back down (per Ford manual). I actually marked that spot on the spring bar jacks with a yellow paint pen. Now every time I hook up, that's where I crank it to.
If i find the ride a bit too bouncy, I'll lower the jacks a bit to put more weight on the tongue, but generally speaking the setup is not finicky at all.
Good luck!
Pete
Good luck!
Pete
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
