lawdes
Sep 09, 2015Explorer
I too have the PP3. I have found that if one backs with too much of a jack knife, or turn too sharply, that yoke will tend to slide. i think it is made to do that rather than break pins, which the Hensley is designed to do as I understand. When that happens, I notice it may crab a little in its tracking behind the TV. I just loosen the nuts on the u-bolts and adjust, and re-tighten. Did have a problem with one of the jacks leaning out, and solved wiith some steel plates on both sides of the frame under the WD jacks.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
